Need Help
S14K's
Car: Drifting
I am in the process of swaping the SR20 DET from my Silvia to my 89' 240 SX. I do not want to pull out the wiring that goes to the brakes of the Silvia and use that on the 240. Instead I want to cut and splice thw wires so that I can use the exisating Wiring in the interior of the 240. I figure that if I cut the wires near the SR's ECU, I can splice the 240's wires there so I can use the SR's plugs. So basically I need the wiring Diagram for the S13. I want to try and get this done by mid afternoon tomorrow! Any one know where I can download one?!?!?!?! I can not stand the thought of transfering the entire Silvia harness (from the doors back to the rear lights). My Silvia would feel naked!.. On a happier note... Even if I end up going through a **** load of trouble to make this run, at least I am getting some of my money back out of it.. I found some Japanese Yen under the carpet.. heh..
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Try these forums you will get more replies:
http://www.nissaninfiniticlub....mid=7
http://www.nissaninfiniticlub....d=138
S14K's
Car: Drifting
I managed to track one down in the area. Thanks a lot though.
