+1 The MREV2 is designed for the REVUP VQ engine...not the older design (03-04). On REVUP engines it will make a large, very noticeable, difference in the mid power band. It is one of the best mods you can do for the 05-07 coupe and 05-06 sedan.tollboothwilley wrote:The MREV2 is a ported/polished version of the lower plenum that you have in the non revup engine. Hence, it will make some difference, but it has been said its not worth the extra cost associated with it normally.
I want it!!! lol. Can't afford it, otherwise I'd take it off your hands.cheapazz wrote:What happens if I put it on a non rev-up motor? Yep, mines at 6600. Bummer. I guess I should just leave it. So its not the best for "all 05+ G's" its the best for 05+ with the rev-up motor.
he wants the 5/16 with the MREV2 for some reason...Sentientbydesign wrote:Why are you trying to trade spacers?
Good luck on the P&P.
Forged pistons, titanium valve springs and possible a few other things. You basically have to have the engine "built" in order to handle the higher reciprocation speed. I think torque starts dying around 6000 rpms, so getting it up past 7500 may be useless.Satter66 wrote:Has anybody figured out how to change the red line point in an engine. I.e 6600 to say 7500 with cams, crank etc?"!? Without buying another motor or car? I'm sure ECU Flashing helps some, however, there must be a way. I had a friend who had an acura integra that red lined at 9000 or so. It was way cool. Kind of like my R1.
Get underdrive pulleys if you want low end responsiveness.cheapazz wrote:WELL YEA!................My reason is trying to get the HP & TQ where I can. I lost sooooo much bottom end after installing the 5/8 spacer. I am thinking of doing some local autocross comps and would prefer to have more power down low vs. all of it in the high end. Plus, in this thread it says go with the mrev2 and the 5/16 spacer. For now I am just going to remove the spacer alltogether and see how it feels. I would also like to find where to flash my computer or if switching the G ECU for the Z ECU would work. I know it would have to be the same setup but could it work?
I'd say stick with the 5/8
But thats just me
