Need help
don roma
Car: 1985 BMW 735i, 1996 Q45 t
Hello
I got a 96 Q45 with 159ooo Km on it, today while driving the car on the highway. I was passing a car, while I revved to 3000rpm to make my pass. the car made a squeeking sound, like a belt was really tight, got me worried, when I parked the car, I looked under the hood to spot anything different, but nothing, and it wouldn't make that sound while revving in park. Also the check engine light came on as well. Anyone have an idea, has this happen to anyone else?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, with no maintenance history, very difficult for us to tell.
When's the last time you replaced accessory belts and pulleys?
Modified by maxnix at 2:52 PM 4/1/2008
qship96
Car: 1996 Infiniti Q45
Have you had the codes read for the check engine light? I would start with that, and see what comes up.
don roma
I have only owned the car for a month or so, I have some mainteance history, the accessory belts have been replaced before,but I didnt see any paperwork on the pulleys. When accelerating from stop, the fan seems to spinning faster making a semi-truck sound, then after 3k rpm it starts to squeel. After I did some searching on here, it seems to me that its my fan clutch. How would I check for bad pulley, and also how do I read the codes.
Thanks
96Qowner
Car: 1996 Q45
don roma wrote: When accelerating from stop, the fan seems to spinning faster making a semi-truck sound, then after 3k rpm it starts to squeel. After I did some searching on here, it seems to me that its my fan clutch. How would I check for bad pulley, and also how do I read the codes.
Thanks
Bingo! Sounds like a bad fan clutch. You can try to find a used one on NICO's Infiniti Parts Forum or get a new one from Joe.
zerothread?id=277766
http://www.infinitipartsusa.com/
Wiggle the pulleys and check the codes with any OBDII code reader.
qship96
Yes, that does sound like the fan clutch to me also- a simple do it yourself repair. Bad pully bearings cause more of a screeching sound-do the clutch and see if all is quiet.
Rent/borrow/buy a OBD2 code reader to figure out why light is on.Here in USA, they are inexpensive to buy, or many auto parts stores advertise they will read them for you for free- check around in your area-pretty basic and popular to get further assistance locally
don roma
Update.
Will be scanning the car in few hours, lucky one the guys from the local bmw club has a scanner I can use . Called my parts guy, gone for the day, but the fan clutch retails at $102 CDN, but my parts guy will sell it at cost when I call tomorrow.
qship96
Great on the code reader- keep us informed
Good price on the clutch, should take less than 1 hour to install!
don roma
Update...
I got the car scanned
P0325 Knock Sensor, Bank 1P0156 Rear H02S Sensor, LH Bank
Time to do some homework
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Might as well start reading the under plenum posts.
don roma
already started
