Need Help
Nissan 350z / Nissan 370z general community discussion forum
Vic's Stang
Car: 2003 Nissan 350Z
Ok my 2003 350z is starting to make a rumbling noise on the front passenger wheel. I took it to a mechanic and he said it wasn't the brakes or rotar. I replaced the brake pads. And the noise still continues. The mechanic said it might be bad tire wear. What do you guyz think?
C-Kwik
Can you describe the noise better. Perhaps also include when it occurs?
sluggoZ
Car: 2004.5 Nissan 350Z Touring Roadster Super Black/Black
Vic’s Stang wrote:Ok my 2003 350z is starting to make a rumbling noise on the front passenger wheel. I took it to a mechanic and he said it wasn't the brakes or rotar. I replaced the brake pads. And the noise still continues. The mechanic said it might be bad tire wear. What do you guyz think?
Take it back to your dealer...their was a TSB, Technical Service Bulletin on the clunk noise from the front suspension.NTB03-088a Oct., 3, 2003.
sluggoZ
Could also be listed TSB, # 03088, date, 10-28-2003Component: Suspension: FrontSummary: Clunk noise from front suspension
also check out your shocks!
http://www.nissanhelp.com/Bull...3.htm
Anthonysflying
Car: 2004 Silverstone 350z Touring
low power steering fluid will make an interesting grinding/rumbling noise.
Vic's Stang
It only happens when you are coming to a stop then you hear like a loud noise
jonthan_hernandez76
Car: 2007 350z
maybe the plastic in front of the tire is hitting your tire? this happend to me once, with my old car. the ball bearings on the tire?
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
jonthan_hernandez76 wrote:maybe the plastic in front of the tire is hitting your tire? this happend to me once, with my old car. the ball bearings on the tire?
tires dont have bearings...
Vic's Stang
Well I hope it is just bad tire wear. Anybody have any advice on what I should do next if its not the tire.
Vic's Stang
going to get my shocks looked at and my car is still under warranty at the Nissan Dealership, so I will take it to see if there is any problems on the suspension.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
He better check his head light coolant and exhaust fluid.
jonthan_hernandez76
Car: 2007 350z
In an automobile, ball joints are spherical bearings that connect the control arms to the steering knuckles. More specifically, a ball joint is a steel bearing stud and socket enclosed in a steel casing. Ball joints are the pivot between the wheels and the suspension of an automobile. Ball joints play a critical role in the safe operation of an automobile's steering and suspension...i actually looked this up just for you...yes tires have "bearings."
Modified by jonthan_hernandez76 at 10:58 AM 3/15/2008
rmezz13
jonthan_hernandez76 wrote:i meant ball joints... i guess if u were a little smarter, u would have figured that one out.
Just making a joke (i was) i figured you meant wheel bearing. But its all good!
jonthan_hernandez76
Car: 2007 350z
that comment was meant for the other guy, "S3t0_S13 "not you, i know u were joking.
Return to “350z / 370z Discussion”
