need help?
truesports03
Car: 2003 nissian maxima
hi, well i got a set of 18inch wheels and i need help picking out the tire size. 235-45-18 or 225-45-18. i have 235-50-18 on there now and they are balloons and they rub in the back but i like the width. some pics of your cars would help.thx
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
depends on width of rims. if you're runnin 7's put 225 45, if they're 8's put 235 45. also depends on if you're lowered. if so, go with 40 series.
Klepton
Car: 1999 Infiniti I30 (Limited Edition)
If your Stock tire size = 225/50/17, then your overall tire diameter (tire height) = 25.85 in.
The 235/50/18 tires you have now give you an overall tire diameter = 27.25 in., which results in the following:
Speedometer Difference: 5.410% too slowDiameter Difference: 5.14%
The 235/45/18 tires will give you an overall tire diameter = 26.32 in., which will result in the following:
Speedometer Difference: 1.822% too slowDiameter Difference: 1.79%
The 225/45/18 tires will give you an overall tire diameter = 25.97 in., which will result in the following:
Speedometer Difference: 0.461% too slowDiameter Difference: 0.47%
Since you should stick to as close to the same tire diameter as your stock tires provide, I'd go with the 225/45/18 if I were you ...
