Samabra »
https://forums.nicoclub.com/samabra-u1847.html
Tue May 13, 2003 4:39 pm
OK check if your fuel pump is priming. What your going to do is put the key in the ACC position, and have a friend back in the trunk area. He should hear a very slight mechanical whirring. If he dosn't then your fuel pump is either not getting power, or its bad. If he does hear whirring (or you can got directly to this test) I would move to the front of the car and remove the pressure fuel line (the one that comes from the fuel filter) then crank the car and see if fuel comes out. If no fuel comes out then you have a clogged filter, bad pump, clogged line, or pump not getting power.
Try these and let me know what happens. Also you could always just remove the fuel rail, turn it upside down (WATCH YOUR EYES) and crank it. If you don't see fuel come out, then you have a problem. Try the above tests and post the results. Good luck Chris
