89S13SE »
https://forums.nicoclub.com/89s13se-u43473.html
Thu Aug 03, 2006 3:48 am
Just finished the SR20DET swap in the 89 240sx.
When I went to start it, the RPM needle was jumping up and down during cranking and when the car turned on (only for a few seconds), it sounded like a lawn mower then the motor turned off. This happened a few times so we re-did the timing (aligned the yellow dot on the pulley to the pointer and for the distributor / crank angle sensor on the head, we lined it up with the first dot).
Now the engine will not turn over, all we hear is a loud click from the starter.
We even jumped the battery with running car and still nothing.
What’s weird is also when the motor was on for that few seconds, I tried to give it gas but there was no throttle response at all. the RPM would flucuate like crazy up a few 1000rpm (0-1000rpm then 0-4000rpm) .
If the starter is bad, is the KA24DE starter interchangeable with the SR20DET?
I dont see any CEL either. I'll look more into it when i get home.....
PLEASE HELP!
Thank you in advance
Modified by 89S13SE at 7:20 AM 8/3/2006
