Need help!!!!!!!
oneruffryder42
i just swaped my ca, and left it at 0.4 bar. and today i turned up the boost to see how it will fill. i turned it up to 1.5 bar and felt like 0.4bar. i dont get it at all?? on my old ca i ran 0.9 bar and the car fe lt WAY faster on 0.9 bar then on 1.5 bar.
Could it be the timing on the car is way OFF. cuz i did not mess with the timing when i swaped in it. what is stock timing??? and where should i put it???
here is what i got thanksgtri t28450ccz32maffmicturbo back exchiped ecuand all the other stuff.
thanks for your help.
damesta
Stock timing is 15 degrees
Nunook
You sure that ur boost gauge and boost controller are working good?
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
looking at your motor, your timing marks read, -5,0,5,10,15,20 and yes like they said, set it at 15
float_6969
WRONG!!! It's 15 degrees for the CA18DE, it's 10 degrees for the CA18DET read the FAQ a little closer.
BUT, I don't know that the extra 5 degrees would cause that much problem as long as you're not detonating.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
float_6969 wrote:WRONG!!! It's 15 degrees for the CA18DE, it's 10 degrees for the CA18DET read the FAQ a little closer.
I dunno... 1.5 bar is like 22psi. First off, thats past the efficiency of the turbo so all you are doing is pumping hot air. Second, you are most likely detonating and the timing is being retarded to hell and back. 22 psi on 93 = on a T28. Really should only go to 18psi(ish) max.
float_6969
damesta
Stock timing for the DET and DE is 15 degrees. The FAQ is a misprint, I had a big thread about this a few months ago trying to figure out if it was 10 or 15 degrees. Check the FSM, your timing should be at 15 degrees.
oneruffryder42
thanks guy. ill take it to my shop and have them set it at 15 deg. ill keep u posted and see if that is it. thanks
boost gauge and boost controller are working good. thanks
c-rad the car is at 7 psi right now just to let u know
