Modified by capwred at 3:51 PM 2/26/2006nismoplsr wrote:Cog? Off? If this is what you mean its been discussed millions perhaps billions of times. Search. Thanks.
thanks and i did search and found out that most people end up messing it up to get it of.xyster wrote:It really has been discussed a dozen times. I've taken one off before....search.
But, since i'm a nice guy, I'll tell you what I did.Drill two holes in it 180 degrees apart. Tap them, thread bolts in, and use a puller plate. Combine this method with heat on the cog if it's tough. The part number for the replacement cog, key, and plate are in the parts list (might still be a sticky).
Now, check your attitude, and search next time.
Nahh, what is it, cast iron? It took me all of 15 mins to drill and tap it. But, you're partially right, don't expect your Black and Decker cordless sheetrock drill to be up to the job. You need something a bit more heavy duty.f s t caz wrote:and just so you know, thats no simple hunk of metal to drill/cut thru. you will break many bits if your not careful because it is very very hard
Nope, it's hi tempered steel.xyster wrote:Nahh, what is it, cast iron?
