I do want a smooth bottom end, I want to get the crank balanced and everything totally cleaned up. I would like to get the head and block decked for flush mounting surface.Sileighty_85 wrote:If you want a fresh bottom end you can't just put in new rings you need to bore and hone the cylinders and get the correct oversized pistons and rings
Not at all. Right now my car puts down 242whp. I AM NOT building this motor with any goal to be putting down more power, it may be in the cards later on but Im not planning it.DriftBoy07 wrote:your talking about adding almost 100hp to a car
And thank you for telling me straigh up that I DO need to make sure they are all the right size.Sileighty_85 wrote:yes you need to get the correct size bearings if you do not the clearance will be too great you will have low oil pressure and eventually tear up and spin the bearings
Bores will probably be worn .003 thousands of an inch. The hone will take the last .001 or .002 thousands. So, converting to metric unit of measure, you will need 86.12mm rings. 86.5mm is .020 over, that's way too much for re-ringing a stock bore! Also, keep in mind your piston clearances will be greater, so you may get a little piston slap on cold start up, but not too bad.white90esex wrote:So being 86mm is the stock bore, if I go with a 86.2mm (if possible to machine that little) or 86.5mm then id be ok to use the stock pistons.
All sounds good, but why are you cracking on Cometic? Ive been running the same Cometic hg for 2 years now. Never had any problems with it. Now im on a spec r turbo and plan on going injectors and mafs this year. And it will probly still hold. No arguments, just wondering what everyone complains about, like Megan coilovers being too stiff or soft, bs. Alot of people talk shiz on Spec. Fck Spec, mine fell apart after 2500 miles. No drifting. lol.Sileighty_85 wrote:Well you need to check the clearance on that 16 year old oil pump if you decide to not drop in a new one if that oil pump goes while your driving that engine will be toast and you wont know it until its too late unless you have an oil pruessure gauge
You need to bore and hone the cylinders if you want good compression the rings to last another 16 years
Over time the cylinder walls become uneven like / \ or \ / so you need to bore and home them to get them straight again | |
you dont sound like you know much about engines therefore i woud suggest leting a professional put this engine together for you
I just read/heard alot of stories on them.You'll rarely hear any stories about an Apexi or Power Enterprise H/G blowin out. I've maybe only heard like 1 or 2 of them but it was due to overheating.corey240 wrote:
I love the confidence haha :Pcorey240 wrote:And it will probly still hold. No arguments, just wondering what everyone complains about,
Yeah these are true, I have friends with Megans, they do not recommend them (front coil brackets seized)Spec yeah Fu*k that clutch i had a friend who had one for 2 months before it grenaded on him just DD itcorey240 wrote:like Megan coilovers being too stiff or soft, bs. Alot of people talk shiz on Spec. Fck Spec, mine fell apart after 2500 miles. No drifting. lol.
Well you can get one cheaper herehttp://www.thenismoshop.com/ik...d=284corey240 wrote:But yea its all been covered. I would replace bearings, and rings, all seals, everything decked, cylinders honed. DO NOT PUT THE ENGINE BACK IN WITHOUT A NEW OIL PUMP! It will be the best 250 you spend ont he whole car, knowing the oil pump isnt gona go out any day now. Im waiting
