fixer »
https://forums.nicoclub.com/fixer-u98517.html
Thu Jan 21, 2010 3:33 pm
in may experience if the fender and hood lines dont match ofr fender and door dont match, then you hit it hard enough to bend the frame. you will need to have the frame pulled by a reputable body shop. If the body lines match tnen you probably bent only suspension parts which can add up to $$$. if you lowered your veh without putting a camber kit, then you dont care about tire wear anyway. also when frt suspension had an impact the mounting cone in the knuckle usually makes the hole bigger and the nut gets loose. be sure to check for play in the lower ball joint/knuckle
