NEED HELP!! sr20det really bad idle, plus stalling and dying...
sr_powered
Car: 1990 Nissan 240sx SE
my engines got really rough idle, also stalling and dying during cold starts. i just installed a thermostat for the usdm sr20de, and it started doing this. please help. im running with no filter, 3 inch down pipe, stock boost, and all stock.
Silvia007
Car: 93 Nissan 240SX SE Fastback
So, it all ran fine until you installed the thermostat?
sr_powered
all the rough idling and stalling and dying weren't there until i installed the thermostat. after that, the car idle below 1000 rpm, (1100rpm-1500rpm before)but keeps stalling, going from 300rpm to 1000rpm, not fast, but like its choking. then it dies. my timings also not right. i couldn't fix my timing cus the idle was too high.
Silvia007
Changing just the thermostat will not do that to a car. I'm gearing towards bumping something lose when putting everything back. You should double check.
fregisr
Car: 240sx 1990
double check all your hoses
vutony
check this site out...mite help u
http://www.frsport.com/sr20det....html
