NEED HELP! Sr20 install
Jon FLA
Car: 1994 Convertible 240sx
I installed everything and the engine started first try. Everything sounded good and normal, then the motor just shut off. Now it wont start. I dont have the intercooler or piping installed, or the maf, just bare engine to see if it would start. I checked if my fuel lines were crossed and they are good. It is weird because it started and was running good, then cut off.. and now it is turning over but wont start..
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Check fuses.
92SEric240SX
Car: 1992 Sileighty with S13 Blacktop SR20det
check your battery, it may not be charging due to lower harness/ alternator issues. check the 75Amp fuse (big grey one)
