can anybody email me a diagram for the dash plug swap from the sr wire harness. I mean after I cut the white part off the sr plug and tried to match up the colors, there are two wires that don't match up. They both have 12 wires. On the ka plug(brown) that I'm going to solder to the sr harness, there is a red wire and a green wire with yellow stripe. On the sr harness, there is a red wire with white stripe and an orange wire with black stripe. I need to be shure which wires go to which before I can start soldering. Also if you guys have the info on the three plugs in the engine bay that would be a big help.
thanks
