Rosco »
https://forums.nicoclub.com/rosco-u15015.html
Sat Sep 12, 2009 7:37 am
So my SR's running so rich to the point i can see loads of black smoke out of the exhaust. It acts like a boost leak(i have no boost leak) until after 4kRPMS and then revs normal....Things I have done: ECU code check: Code 55 all clear Changed Z32 MAFS Ran B12 Chemtool through one tank of gas seemed to only work for 5 days Changed T-25 wastegate Checked grounds all good Plugs are fouled with carbon buildup (due to running rich, duh!) I do have a small exhaust leak (definately not the prob tho) SAFC was readin only 30% Airflow at 100% throttle I have 2 MINE'S tuned ECU's which I inspected for burns and there where none..... BOV is re-circulated....I took an OEM FPR off of my spare SR and still no change I will be checking Voltages today on the TPS, MAFS and whatever else I can.
The car had been running good for 2+plus years and this is the first "major" trouble I've had.....Any ideas??? OOPS wrong SR20DET Forum.....meant for RWD one...
