Gutling »
https://forums.nicoclub.com/gutling-u27213.html
Thu Jul 28, 2005 2:41 am
Alright, I have a 1989 nissan 240sx with a redtop sr20det. I recently put it in the shop to have a bunch of modifications done on it, the current setup is a Greddy GT25R (not the 400hp one, basically a stock replacement, bb) Sard 550cc injectors, turbonetics mbc, hks bov, front mount intercooler, megan o2housing, 3"downpipe, 3" megan exhaust, z32 mafs nismo intake, walboro 255, ssautochrome exhaust mani, SAFC II, blitz turbo timer. Anyway, the problem i was having started before the injectors, turbo were installed. The car would crank fine, rev up freely in neutral. however in gear, it would pull fine till ~3000 rpms, or if you slowly eased the gas a bit higher, then it would stutter horrible, and drop rpms to ~1000 until u released the pedal. u can keep it floored and it will never go about 1000. stuff i have checked/replaced. redid the mafs wiring from the ecu, it was butt connected 3 times and not chassis grounded at the mafs. fixed that, still did it. switched out the z32 mafs with one from a j30, still did it so mafs is good. that leaves me to believe it is the ecu. i have ordered a new oem one, and will have it friday. but is there anything else i can check, try out, wiggle, replace? voltage on the mafs, it would run fine until 3volts, u can keep it at 2.9 and drive it all day, the miute it hit 3 it would drop to 1.
