RMiller,I'm using the Bosch O2 sensor from the 87 300Zx turbo as well but I smashed the connector from the SR harness that goes to the connector on Bosch O2. Do you happen to know the wiring info for that sensor? It has the 3 wires (red, black, white) but I don't know which color wire sends the signal to ECU. Could you be so kind as to check on your SR? I tried asking on the other forum (FA) and got no help, not even an answer. I tried searching on this forum to no avail as well. Thanks in advance.RMiller wrote:You can use a number of different o2 sensors. It's 3 wire, right? You can use a Bosche 3-wire universal. I use that on my CA, which can also use the 300zx sensor. ......
Yeah sure. The black wire on the sensor is the signal wire. The other 2 wires are not polar and are your power (heater) wires. So your signal wire goes to black, the other 2 go on the remaining wires.BigJuiceSr20 wrote:
