Need help, speedo not working, other warning lights
General discussion area for the L32-chassis Altima
ablkop
Car: 2009 Nissan Altima 2.5S
Replaced my hub assembly on passenger front. When all put back together, speedometer doesn't work and warning lights for key, abs, brakes and 'service engine soon' stay on. Car starts and drives but warning lights stay on when running. Key warning stays on after engine shut off.
Understand abs light being on as may have done some damage to abs sensor. Speedometer worked fine before hub replacement and warning lights were not on. Anyone have some ideas of what might be the problem and how I may be able to fix?
machusenpai
Car: Nissan Altima SE 2007 Manual Transmission
Omg I have the same problem. I replaced wheel bearing (hug assembly) and suddenly speedometer isn't working properly.
ablkop
Have you had any luck finding a solution?
machusenpai
Nope, no luck so far and I haven't find anyone that has the same problem...We clearly need help and I don't want to go to the dealer as it will cost like 2k$...
MalcolmY
Any updates?
ablkop
No updates yet.
CV boot?
Anyone have some ideas?
centralcoaster33
Car: 1997 Nissan 240SX #5
Two similar projects on similar modern cars, no working speed-o and warning lights flashing. No one has pulled a code from the ECU? Please check for codes and post back if you can.
FSM - TM chapter states that the estimated vehicle speed signal is transmitted from the ABS actuator and electric unit, so having possibly messed up your ABS could have an effect on your speedometer. I pulled the one for 2009 and am looking at page TM-353. Now, I didn't dig real deep and I only looked at the 2009, but that should be similar for both of you. I do see info for the CVT in there as well. So, look around the FSM stuff and see if you can't find what you're looking for.
http://www.nicoclub.com/service-manual? ... ma/2009/TM
Return to “4th Generation Altima Sedan (2007-2012)”
