pj »
https://forums.nicoclub.com/pj-u25266.html
Thu Aug 05, 2010 6:03 pm
i have a few ideas for you man.
if its locked up, take the plugs out and see if itll spin, if it spins, its not done yet.
check to make sure youre getting spark to all cylinders,
make sure all injectors are working.
make sure you didnt skip a tooth on the timing chain or the timing is off.
make sure you installed the guides correctly.
take the transmission loos, check the clutch. i personally have had a clutch kill itself and a peice hung off and slapped the bell and made a crap load of noise.
ive dealt with all of these things except the timing chain, i changed it and had no issue. other than that all these things will make a bunch of noise.
you can probably rule some out in about 15-20 minutes....so get to it haha
