amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Wed Sep 13, 2017 1:44 pm
Then why complain about what is apparently 'normal' there..................I daresay you didn't buy a new car looking like that...................my judging of the pic and trying to include the slight angle it was shot at seem to indicate the hood is curved up in center and the front grille surround is dead flat across the top, that screams hood is the problem rather than grillework. The placement of the outer hood holddowns reinforce that if indeed they are actual holddowns and not just eye candy pieces. A true centered single holddown like OEM could be adjusted to bring some of that out.
But then I tend to think WAY out of the box and why so many things I do turn out right when others say no, no, no, you can't do that.
Look at what changed from the OEM there, the hood, no way will I accept that they all have problems that great. More evidence? Look at your outer plates that appear to screw into the hood, they don't fit dead flat on the hood surface either at the front. What custom hoods do better than anything else, not fit exactly right like you want. You have to bend them into proper fit using a variety of ways that hopefully do not lead to cracking later. I used to install glass pieces on a lot of race cars, NONE of that stuff ever fits 100% right until you make it happen yourself.
The OEMS may not fit perfect either but in your case I'm pretty sure the hood is adding to the error there.
Luck.......................mine does not look like that at all.
