Boney wrote:I just started up my SR and its idling pretty much fine but the engine sounds rough like the timing is off. My TPS voltage reads 0.37 and I cant get it any higher.. I know you have to change the CAS until the second timing mark is on the tab.. I cant get my timing light to work.. I hooked it up to the wire that coils out in the back, on the 1st coil wires.. just wont go. Even tried another gun and still nothing. Can someone explain the procedure? Thanks.
don't use the wire in back. cut the end off of another spark plug wire and cram it into your coil pack and wrap it in electrical tape. then put the other end where it obviously goes and hook your timing gun onto that.
