MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sat Jan 10, 2009 6:46 am
Does the car try to start? If the alarm is preventing starting, the starter will not even engage.
Try locking and unlocking the driver's door with the key. You might also want to try locking the car with the door open, then closing it, then unlocking with the key (as though you're getting out to leave the car). Since you don't have a keyfob, you have probably already done this. But using the key in the driver door SHOULD shut off the alarm once it trips.
The car did originally come with a keyfob. The unlock button on the keyfob normally disarms the factory alarm. Ebay is usually a good cheap source of keyfobs if you want to buy one.
If it's an aftermarket alarm, I'd recommend finding the alarm module and disabling it. Otherwise, you can try removing the factory alarm fuse (probably labelled "anti-theft" and probably under the hood...I don't know for sure with the ~'99).
