Okay, this is a tough one since the engine wasn't bought as a complete unit.
I just checked and you have a Kouki MAF.
http://www.240sxmotoring.com/partnumbers.html
My MAF is a Zenki S14 SR since it ends in 00. Yours is 01, therefore you have a Kouki MAF.
Now that we know you have a Kouki MAF (which by the way are really rare to find), did it come with the engine you bought, or did the people just give it to you off the shelf?
Here are two things that you could check for:- I believe, if there are fins on the head, it is most likely a Kouki. Then again, there was one transitional year when the Zenki had fins on the head (which is what I have, and I know for a fact it's a Zenki).- Check the coil packs. Most likely they weren't replaced. If you check an older thread, in the SR forum, it tells you how old the engine is.
If you don't have fins on your head, it's likely it's a Zenki.
Finding S14 SR MAF's are hard as it is, and worse comes to worst, you could just get a Z32 MAF, that is assuming your ECU is right though.
Also, there are three S14 SR ECU's. One is black WC, red WC, and NA (Kouki). I forget which WC I have, but the different color represents that transitional year.
