need help! s14 peeps
night240
Car: Nissan 95
Well hi everyone uh I have been active here, but I have a problem with my S14. My problem is recently not to along my tailights won't come at night time and also cluster gauge went out too; however when I press the brake everything lights up at the back.
I have search , but I do not have after market radio. i'll check the fuse again.
I don't have this white box that nico shows in the picture? is this a problem?
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
night240
Car: Nissan 95
scotty-2-forty wrote:Try this thread ... s14-tail-lights-not-working-tried-every ... 83562.html
thanks I'll try and I'll come back with some update.
s13sickboi
Car: 1997 Nissan Hardbody XE
night240 wrote:Well hi everyone uh I have been active here, but I have a problem with my S14. My problem is recently not to along my tailights won't come at night time and also cluster gauge went out too; however when I press the brake everything lights up at the back.
i believe that pic is of an s13...
night240
Car: Nissan 95
i thought it was s14 looks like to me. :frown:
night240
Car: Nissan 95
update I check dimm switch didn't a thing. so...I'm thinking wiring's is cause or maybe maybe change bulbs? :frown: I turn on head light still no light on my cluster. hmmmm
s13sickboi
you say you dont have an aftermarket radio? cuz that was the problem with mine.... i was stupid and shoved a peice of wire in the fuse to keep it from blowin (this was before i found the issue) and the result was a thick cloud of smoke and a mess of melted wires (and no lights)... are fuses blowing in yours?
night240
Car: Nissan 95
s13sickboi wrote:you say you dont have an aftermarket radio? cuz that was the problem with mine.... i was stupid and shoved a peice of wire in the fuse to keep it from blowin (this was before i found the issue) and the result was a thick cloud of smoke and a mess of melted wires (and no lights)... are fuses blowing in yours?
Yup, no after market radio. I never see smoke or smell in my car. I hope it's just the fuse or maybe I put the fuse in wrong place? :gotme
s13sickboi
yes but are you blowing fuses?
scotty-2-forty
s13sickboi wrote:yes but are you blowing fuses?
And after blowing the fuse, comes smoking in the smelly car. :naughty: Bah, nevermind. On a serious note, I didn't get to take any pictures for you night240. You still need 'em?
night240
Car: Nissan 95
yes, sir I still do.
scotty-2-forty
Here ya go ... mind you mine is a '96 SE, but hope this helps. Pay no attention to the messy wiring, as I'm in process of redoing a few things.
night240
Car: Nissan 95
see my doesnt have the white box stated up there.
is the white box?
and thanks so much scotty-2-forty
night240
Car: Nissan 95
problem solved: it was the dang fuse. :)
s13sickboi
night240 wrote:problem solved: it was the dang fuse. :)
love little simple things like that dont you? lol :dblthumb:
night240
Car: Nissan 95
hella yeah! :) :chuckle:
night240
Car: Nissan 95
soo ok problem came back my tail lights at night went out. I was like wat the hell??? and as soon as I stop a gas station and replace new fuse, after driving like 5 mins tail light went out again wtf?? soo it isnt the fuse at all.
Legion76
Car: 95 Zenki, 99 Ram 1500
Sounds like you have a grounding problem. One of your tail light wires might be rubbing and the insulation is damaged or you have a bad connector. You have to find the reason the fuse is blowing. Best bet is to start at the tail lights and inspect the wiring/connectors and work your way forward.
night240
Car: Nissan 95
Legion76 wrote:Sounds like you have a grounding problem. One of your tail light wires might be rubbing and the insulation is damaged or you have a bad connector. You have to find the reason the fuse is blowing. Best bet is to start at the tail lights and inspect the wiring/connectors and work your way forward.
thx for ur advice I will do that until during noon time. that time I will take to the shop.
