Need HELP! S14 95, will pop but no run!
rh4motorsports
Car: LS13
Hey I picked up a great deal on a 95' S14 se, it's an auto, but would be a awesome daily driver (Seattle area traffic lol) The car is loaded, has oem alarm, leather, the works and everything is factory!
Anyhow, I bought the car since the owner said the "timing chain needs replaced" , well simply put the top guide was still in there lol. I picked up the car, Engine bay looked crazy clean, there's evidence of the top front cover having been removed, looks to be a new distributor and water pump also.
What is happening is the car will pop and sputter, but no consistent running.Once it pops or sputters then it will not pop again on that crank over cycle.I did get it to fire and run for a few seconds, ran perfect for those seconds, but just as fast as it started it instantly stopped running, in it's tracks quick stop.
The fuel pump is working fine.
Tried a different 95 ecu, didn't seem to help.
Just tried 3 different 95 distributors, didn't seem to make much of a difference on which one it liked most lol.
It seemed that when I would try to fire it, it would pop, not try to pop anymore, then I would adjust the timing, then it would pop again.
I've been through the timing multiple times, I've assembled plenty of ka's so I'm confident the timing chains and distributor are right, but I could really use your ideas or if you've had similar problems!
I'm hoping to get a OBD port reader out here and do the self diagnostic on the ecu tomorrow.
on a side note the car has been sitting for 3 months also, but you wouldn't know it by how clean everything is!
Thanks in advance for all your help!
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
have you tested the coil?..cap..plugs and wires?..seems to me to be electrical
urbanskiben
Car: 1991 240sx with 93 motor bored out
um you timing is off one tooth so jus reset crank to tdc start going though to reset your cam gears tere is a write up on the tech page
