ffmpr604 wrote:I recently installed a home-made hydrogen generator on my 2007 Versa with CVT. The idea is that the HHO gas is produced and ran into the air intake.
No offense - but it does not work. High school chemistry and physics... you can simply not create more energy by using electricity generated by the car to distill water and create hydrogen to burn. If it worked - humans would have stopped using gasoline engines long ago.
You then modify the air intake sensor signal to lean the air/fuel mixture saving you gas. My car now rev's up and bounces the rmp's up and down. Ex. On the fwy my rpm's will be at 2,000 then rev up to 2,500 rpm's. It does this every 4 seconds or so. Any idea's ? Everything on the generator side is back to factory settings.
The rpm jumping up and down is caused by the increased electrical load your snakeoil generator is creating. The same effect can be replicated by say... pressing the power window buttons.
