need help. rim sizess
bjm240
Car: 1995 Nissan 240sx
iv got a stock 95 240sx se. i want 17"s but i dont know like off sets and all that stuff. so what would be a good size???
xX RB Xx
Car: SE3P, FC3S, FC3C.
17x8.5 +17 in the front17x9 + 11 in the rear
or something along that lines.
AZ89two4Tsx
It all depends on how much you are willing to do to make your wheels fit.
Those sizes that xX RB Xx just gave you will stick out without camber or a pull.
Nali
Car: Datsun Nissan 280ZX
Check through this site till you find a nice stance you want then just find out what rims come in size.
http://www.rimtuck.com/thumbna...r+asc
E7-S14
Car: ess 14 foo!
xX RB Xx wrote:17x8.5 +17 in the front17x9 + 11 in the rear
ha you'll def. need a rear qp fender pull for a +10 rear offset.
+17 on a 8.5 should clear w/o modification.maybe a small roll..
im running 19x8.5 +5 front and i had to space/pull/roll my front fenders
19x9.5 rear +10 and i had to roll /pull the crap out of my fenders.
my camber is near -4 degrees on both sides.
hope i helped.
it all depends on the "look" your going for.
tire size also plays a great deal into how wheels fit also.
FolkertSX
Car: 1991 240SX
yea i have 17x9 12 offset and on a 30mm widebody in the rear and 20mm up in front. back fit perfect. the fronts going to need a touch of camber
ashibah83
Car: 93 SUPA BLACK COUPE
FolkertSX wrote:yea i have 17x9 12 offset and on a 30mm widebody in the rear and 20mm up in front. back fit perfect. the fronts going to need a touch of camber
they fit perfect on your car because you are 4x4 status, if your car were lowered they would be SUNK!!!
17x9 +12 will fit just fine under stock fenders...with a little massaging
FolkertSX
Car: 1991 240SX
o well what does lowering he car have to do with it. and maybe theyre going to sink in a tad. but still...theyre be far from SUNK
Metal Angel
Car: 1990 240sx hatchback
What is the difference between fender roll and fender pull?
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
Metal Angel wrote:What is the difference between fender roll and fender pull?
my understanding is as such: roll is when the inner lip of the fender is folded or "rolled" in, a pull is when the fender is also rolled and then is flared out, sort of like fender flares.
bjm240
ok but if i dont want to have to pull, roll, space stuff like that. wat would be a safe size to go
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
You need to search, then ask in the technical section under wheels / tires
