Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sat Oct 11, 2003 11:47 am
There are 2 sensors, one on the pasenger front, and one on the rear. They wear, and break contact, causing the message. The best way to get rid of the message, is to use OEM pads, which come with the sensors. The second best way, is to call the local Infiniti parts department, to see if you can buy them separately.
The cheap way, is to cut the wires, and add a wirenut. Be sure to cut the wire right next to the sensor, so next time you can buy the OEM pads, and replace the sensors.
This feature went away, later in the '94 model year.
Right now, mine are wirenuts, but I will replace with the sensors, when I do my brakes next, since we all get a smokin' deal through Joe.
