CanadianCoch »
https://forums.nicoclub.com/canadiancoch-u9918.html
Mon Dec 01, 2003 3:47 pm
come on, have a sense of adventure! This is a 2 on the scale of 1 to 10. There are 8 bolts around the valve cover, and then 3 located in the middle of the cover. If you want a step by step, invest in a chiltons, it has exactly how to do, if for some ungodly reason you can't figure it out. Take out the plug wires from the car. Start in 1 corner and diagonally remove all the bolts, they are 12's or 10's, you can find out with sockets, lol. Remove the cover, and take off the rubber seal. then clean all around the rubber seal, removing any old sealamt. Then Take your new seal, and put itwhere the old one is, MAKING sure to use sealer where the rubber is half a circle. Make sure it is flat, if it's angled when you install the cover again oil will leak. Once thats done, put the cover back on, making sure all of the screws goes through a hole in the rubber gasket. Then diagonally screw in all of the screws, styarting with the one in the exact center, and going diagonally opposite. Tighten them until they resist the whole way around, then a second time tighten them to 70 inch lbs, or 11 Nm.
That is all
Dr.
