M37owner »
https://forums.nicoclub.com/m37owner-u232334.html
Fri Feb 28, 2014 10:49 am
I have not changed one on an Infiniti, but i have repalced a few mirrors on other models. It is an easy job once you get the door panel off (the hardest part). There are two or three studs on the mirror mount that protrude through the door skin/panel so you need to remove those nuts and then just unplug the electrical connector. Window needs to be in up position (at least on the models I worked on) to give you enough room to get your hand in there.
Below is copied from the AllData diy site:
OUTSIDE MIRROR
DOOR MIRROR ASSEMBLY : Removal and Installation
REMOVAL
CAUTION:
•When removing, always use a remover tool that is made of plastic.
•Be careful not to scratch door mirror body.
1.Remove front door finisher. See: Doors, Hood and Trunk\Front Door Panel\Service and Repair\Front Door Finisher.
2.Remove front door sash inner cover. See: Doors, Hood and Trunk\Front Door Panel\Service and Repair\Front Door Sash Inner Cover.
3.Disconnect door mirror assembly harness connector.
4.Remove door mirror assembly mounting nuts, and then remove door mirror assembly.
INSTALLATION
Install in the reverse order of removal.
