Need help replaceing my Fuel Pump on a 1990 S13 Coupe
9095240SXDUCK
Car: 240SXs
OKI just got me a WALBRO GSS341 Fuel Pump.
Anyway I got a 1990 S13/240sx Coupe. (5 speed if it matter). I took the top cover off in the trunk but there is still bolts where the pump is.
So here is my Question do i need to drop my Fuel Tank to change my Fuel Pump or can I do it from inside the trunk.
:help :help
And There is alot of Dirt on top of the cover can I somewhat spay water on top of it or use a wet tower to clean it off? :help :help
And If someone got Step By Step instration it would help alot. And alot of thankfullness from me if you do have it!
NISTECH
shesh I thought i just answered this question or seen it somewhere before????
9095240SXDUCK
Car: 240SXs
Yeah I post it on the other form too!
Sorry!
Touchdown038
Car: Computers, cars, sports
Regardless, you can do it from the trunk. Just unbolt it and pull it up.
The hardest part about this job is getting the o-ring to stay in place while you're putting the pump assembly back down. Either that or reconnecting the fuel lines back up.... hmmm.
9095240SXDUCK
Car: 240SXs
Touchdown038 wrote:Regardless, you can do it from the trunk. Just unbolt it and pull it up.
That Sound like FUN.:ylsuper ;) I am going to play with it tomorrow.It's 12:30 here In ATL and is only 30oF outside so.:pface
But thanks for the Info! Every Bit Counts!:thinker
9095240SXDUCK
Car: 240SXs
OkI need Help AgainMy Lines is stuck where it was clam down. It will turn but it won't pass the clam down part is there anything I can do to help get it off.
I need help ASAP since I am off today and I really need to get it running. Since the Hatch need a new pump soon too.:help :help :help :help :help :help
And yes I slide the clams away from the connetion.
Nathan
Force it...thats my only advice, try shoving a small flathead screwdriver up under the rubber fuel line to break it loose from the hard line.
9095240SXDUCK
Car: 240SXs
would that crack my fuel ine?Since it is 15 years old.
Touchdown038
It might crack it, but force is the only way to get it off.
Another way is to bring out a hairdryer with an extension cord and heat them up a little bit. That should expand them and make them a little easier to pull off.
NISTECH
sraying them with brake cleaner helps too.
9095240SXDUCK
Car: 240SXs
my baby is alive thank's to your.
well it took me coupe trip to the part store to get wires connecters but my baby is good and running.
but it is doing something new.it done this 2 time tonight. When I leave it in N it was kinda like it is chokeing it self or something. I put a new Air Filter before the trip.
but thank's alot your for helping. Hope I can find out wht it is doing now.
oh by the way the car is a 90 KA24E 240SX XE coupe 5 speed.
Hockey2020
what color wire is the power routed? im gonna make a fuel cut off switch and i need to find the lead wire...its a 95' 240
9095240SXDUCK
Car: 240SXs
it was red as I know Of. I did Not really pay attenion.Sorry!
