Need Help! Replace Control Arm?
joneswood
My car is swaying when driving and the rear tires are wearing unevenly. Took the car to the dealership and they are saying control arms (rear) need to be replaced at a cost of $1000 (not covered by warranty). I took the car to another shop and they are saying that the control arms are fine, but the control arm links are bent and need to be replaced at $400. Both are saying the car will also need an alignment. Not sure what to believe. Thoughts?
Ilya
Links? As in stabilizer links? Those cost $30-40/each and take 10 minutes to replace (so long as your stuff isn't rusted to hell). You can probably do it yourself if you have the ability.
Here is my HowTo on replacing them: howto-change-your-stabilizer-links-s-t572905.html
I'd start with those first, get an alignment ($80 tops) and see how the car drives.
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
very sound advice above
built2makeit
Car: 2007 Infiniti M45
Did you figure out what the prob is? Because im having the same issue, had my rear stabilizer baes changed and still feel like in driving sideways. Im lowered and on 20s, and about to be on my 3 set of tires in 3 years so im thinkin camber kit...
