need help removing the head from my sr
luv2spedup
Car: 89 silvia
i need 2 pull out my head from my sr, does any one have any tips or pictures to help me through it
deCksy
luv2spedup wrote:i need 2 pull out my head from my sr, does any one have any tips or pictures to help me through it
go get the FSM and follow the order... its pretty simple... and when you buy the 10mm allen wrench socket, make sure you buy 1/2" drive not 3/8" that **** breaks
luv2spedup
Car: 89 silvia
thanx bro, but i dont think dealer ships carry manuals for sr20det. would u happen 2 know of a dealer ship that might have one. i have been looking for one for a while now
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Make sure to keep everything in order,The same way it looked when you removed it,Cam caps,rocker arms,lifters,and rocker arm guides.remove the head bolts from the outside in.
jt15833
Car: 95' 240SX
like every other swapped in motor there is probably an FSM available on the internet in pdf form, check the faq maybe for one
spider_slayer
Car: S14 240SX
S13 240SX
jt15833 wrote:like every other swapped in motor there is probably an FSM available on the internet in pdf form, check the faq maybe for one
do your self a favor and go to the grocery store and buy hella zip lock bags and label EVERYTHING!!!!
luv2spedup
Car: 89 silvia
thanx for the tip guys means a lot
