Need help removing s13 shocks
mattscar
Car: 1989 240sx, 1992 Miata
Do I have to bleed the brakes? I am sort of confused about it, I'll take some pics tommorow when I go home.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Why would you have to bleed the brakes if you're removing the shocks? They're independent systems.
nismofly
Car: 89 Nissan 240SX Hatch
if youre thinking the fronts, you just pop the clip off and pull the line out of the bracket, simple as that
mattscar
lol sorry I thought it was the same as the corolla.
but are the stock shocks blue?
(Yoshi)
Car: Black 1991 Nissan 240SX Fastback
if they are stock they are black, and they are struts so the shocks are inside the springs...
mattscar
Oh.
btw I cant find the retaining clip holding the brake line
sorry for my noobie question btw.
slavetothemuzic
Car: 1991 240SX Fastback
mattscar wrote:Oh.
It's only on the fronts. You'll see the brake line clipped to a bracket on the strut. You just use neddle nose or a flat tip screw driver to pop that little clip off.
Then make sure you re-attach it to your new ones.
