Need help removing interior trim to get to the stereo
Demiroquai
Car: Infiniti M37
Hey guys, I bought the BeatSonic wiring harness to bypass the DVD lock while driving feature. I'm ready to put it in EXCEPT I don't know where to begin. I do not want to damage my system or interior in any way so if anyone has a video or a step by step on the M37 I would GREATLY appreciate it.
I'll even do a how-to as well to sticky here.
Thanks in advance.
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
I don't think anyone has done this for a M37/56 yet. Check the how-to from the M35/45. It won't be exact but it should provide good starting point and tips to help you along. Yes, please do a how-to with pics and I'll add it to the stickies.
King James
Car: 2011 Infiniti M37 S Tech, Prem, Del, Aero kit
I've installed the Beats Sonic bypass and it is a PITA to get that Dash apart and the amount of items that have to be removed is scary. I guess I should've done a write up. I followed the FSM to take it apart, it took me 1-2 hrs or nerve wrecking time to get it done, Suggestions - Buy plastic panel popping tools, use rags to help againt scratches, when installing the gear shifter back on make sure its in Park or what ever gear you should be in, TAKE YOUR TIME if you care about you M. but the Beats sonic PNP harness is MUST it's worth it. GOOD LUCK
Demiroquai
Car: Infiniti M37
King James wrote:I've installed the Beats Sonic bypass and it is a PITA to get that Dash apart and the amount of items that have to be removed is scary. I guess I should've done a write up. I followed the FSM to take it apart, it took me 1-2 hrs or nerve wrecking time to get it done, Suggestions - Buy plastic panel popping tools, use rags to help againt scratches, when installing the gear shifter back on make sure its in Park or what ever gear you should be in, TAKE YOUR TIME if you care about you M. but the Beats sonic PNP harness is MUST it's worth it. GOOD LUCK
Ok, I'm going to work on this tonight and see what I can do. The one thing I looked at was that the ring around the shifter that holds the leather in place doesn't move. How do I move that down?
Demiroquai
Car: Infiniti M37
It was a b****, but its done... j/k. Took about 45 minutes and $40 from a stereo shop in Santa Ana. Notice, car is in drive.
My only panic moment was the airbag light but I was able to reset that there at the shop.
mcowher
Car: 2013 Infiniti M37x
Has anyone tried this on a 2013 M37?
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
If you search "Prestigious society M37" on YouTube - you can find a video of a guy who tears apart his center console/dash to install their product.
Doesn't look too difficult, just a lot of steps and different pieces to keep track of.
https://www.youtube.com/watch?v=1Wcoe1vZ3f0
I would use some masking tape to protect the dash and dedicated plastic pry tools - he uses a flat head screw driver - yikes!! :ohno: I surprised he didn't scratch up his entire dash.
infinitedrift
Car: 99' Cherokee
11' M56s
03' M45
03' Maxima(SOLD)
08' M35
91' 240(SOLD)
07' Crown Vic (wink)
It's really easy to take a part. I've done it a bunch when wrapping my interior in different wraps. I'll do a write up when I install this beatsonic harness. Just make sure when taking the center console apart that you DO NOT turn on the car while harnesses are unplugged. The airbag light will come on and will need to be reset. Use the shift lock release to move the shifter.
ibc
Car: Infiniti M56x
Here are more photos and info about how to disassemble the console to get to the Nav/Radio to bypass DVD blocker:
http://x.infinitihelp.com/forum/showthr ... 12524.html
mrnix
Car: Currently 2012 M37X, Malbec Black
Formerly 2004 Infiniti G35 Sedan
Demiroquai wrote:It was a b****, but its done... j/k. Took about 45 minutes and $40 from a stereo shop in Santa Ana. Notice, car is in drive.
excellent film choice, sir.
mcowher
mcowher wrote:Has anyone tried this on a 2013 M37?
FYI: I took a chance and ordered this for my 2013 M37x. It works great.
Where is everyone putting their toggle switches?
