aez987 »
https://forums.nicoclub.com/aez987-u27583.html
Tue May 24, 2005 9:44 am
I have been under the car numerous times and have removed some of the miscellaneous screws behind the light housing, but it does not budge. I see a hinge that looks like the rear of the assembly should swing open, but it doesn't.
It appears, although unlogical, that the only way to remove the fog/driving light is to remove the bumper. I believe that because on the side (in the front) there is a little 'reflector' that has a Phillips screw at the top - directly adjacent to the bumper. That 'reflector' seems to help hold the assembly in place.
If anyone has a service manual, or has performed this task before, please help me out here.
BTW: I am NOT trying to simply replace the bulbs - I've done that several times and it only takes a few minutes to do.
