Here's a link to my build thread
http://www.240sxforums.com/forums/begin ... orums.html
I took the following from my thread, unfortunately because I started the thread in the Beginner's Forum, I don't think it gets much traffic:
Finally started to get back to this project! A few things to cover and get clarification on.
First let's start off with whats a NECESSITY for the swap. There is still some debate as to what you NEED to switch between the S13 and S14 engines in order to make the swap work with the S13 harness/ECU. Here's what I've come across thus far. Keep in mind that the S14 engine, and its components, are in alot better shape than the S13 engine and components, so I'm trying to use as many of the S14 parts as possible.
Going to install:
S14 running longblock
S14 transmission
S14 intake manifold
S13 Throttle Body & TPS
The three (3) S13 temperature sensors from the S13 intake manifold (not sure about this since S14 sensors are in way better shape, and they all connect to the same plug which looks identical on both S13/S14. Is this a necessity?)
S13 Exhaust manifold/Exhaust
S13 Driveshaft
S13 Rear Diff
Removing Emissions:
This is really the only guide I've seen thus far
Intake manifold mysteries revealed: DIY KA24DE emissions removal and assembly – NICOclub
I'd like to tackle the spiderweb of hard fuel/intake vacuum lines on the top portion of the S14 intake manifold, but haven't found a writeup on how to simply the system. At this point, I'm looking for any insight or opinions. Emissions in NY State are not my concern being a 91 model. Also keep in mind the car will be mainly a track car.
I know that for the EGR, sites say to keep that rusted brown mass in the intake but to block it off its outlet. Why wouldn't I just remove it altogether? Simply due to it leaving an oddly shaped hole?
Feel free to help me out, I want to get this car moving soon!
