need help removing cluster
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
koolie240
Car: s13 240sx
I need help with removing my cluster, I got it loose, just cant get it over the ignition, all the connections are loose, can anyone help???
FRoSt415
Car: s13 240sx
Fist is it a s13, or s14. s13 the platic trim that holds all the connectors? well you there are two ways to do this. one is rough house it and you might crack it you have to wiggle it then spin it to the left to get it out. number two requiors a 12mm socket and ratchet there are two 12mm bolts that hold the steering wheel up. they are located under the ignition modual. remove those two and the whole steering rack will lower. then after you get it out put the bolts back in and becareful to put them in straight because my friend just stripped on of his. since your there take out the gauge cluster and upgrade to some LED's. hope this help if you have any questions just post again ill check back in a few days.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Technical Articles > Installing Digital/HUD Gauge Cluster http://www.nicoclub.com/articles.php?id=222897
koolie240
Car: s13 240sx
Thanks for the help, I got it loose by lowering the steering colume, and I also put in the LEDs
killedbydeath
Car: Nissan 180SX
pics??
what color led's did you install??
Return to “Interiors”
