need help really bad
KkiepCcaSsau
my 240 hb 91night driving light/break light turn on when the key is in start ignition or car running . the light still on even i took out two plugs underneat in break pedal . anyone please help... i'm in dangerous
i'm thinking the wires are mess up with route or problem with relay
s13sr20chris
send me an email to [email protected] and i will send you the wiring diagram. its a simple circuit. if you can unplug the brake switch and the lights are still on then you are getting power somewhere after the brake swicth. pull all your rear bulbs and check for melted terminals or something. the little harnesses back there can melt too.
KkiepCcaSsau
my email [email protected]
i open all the light bulbs , i check the input and plug it seem fine . i will check the wires again after i get your diagram thank....
last week i went to junk yardi rip off the complete harness on the back but until where the fuse box under the dashi'm stuck there is no plug , the wires continues go up to dash board
KkiepCcaSsau
update, the light don't come on now but sad thing is when i break it won't on either
