brunswick240 »
https://forums.nicoclub.com/brunswick240-u25911.html
Sun Feb 26, 2006 1:29 pm
Alright guys, im having problems with my ka-t setup with it running too rich (fouling out all four of my plugs). Heres the setup:
T25SR SMICRFL BOVSAFC IISSAC Bottom Mount ManifoldSSAC 3inch DPSSAC 3inch Dump Tube
So at first i thought it was my o-rings on my injs, so i pulled the injs and found 2/8 bad o-rings, replaced all 8...Still running rich. Then i thought it was my MAF, made sense, because i was running so rich even with the safc and the safc goes offa the MAF. So i got a working MAF, and it didnt change anything. So i went to check my safc wiring and found out that i crossed the input/output wires for the MAF from the SAFC, so i fixed those, started it up, but it wouldnt let me rev above 3k, almost like it was in limp mode. Now im thinkin that its my FPR (still the stocker), im thinkin that its not getting vacuum to open/close, my reasoning for this is because when i took out my AIV system i pulled off the vac hoses that connected from under the throttle body to the AIV. I know that i dont need the AIV, but i have 1 vac line that i put a screw in to block it off, the other one is being used for my BOV.
I really need some help, ive gotta get this thing running so i can get it tuned, im sick of not having a car and watching it sit in the garage and driveway. So please help me resolve this problem asap. Thanks in advance, sorry for the long post.
