borodrifter »
https://forums.nicoclub.com/borodrifter-u56770.html
Sun Mar 16, 2008 2:26 pm
Hi, Im working on the RB20 wiring along with andy.
We have (as per Carl H's instructions) the purple/white wire spliced into the white ignition fusebox wire. This gives us +12V, fo course.All others are connected to their corresponding wires, again as per Carl H.
The black/white and the purple/white now read a constant +12V.
The orange ignition signal wire is confusing me now. It reads +12V at run/start positin as it should, but I don't know where they go.There are two orange wires from the relays by the ecu, that join together and seem to conenct at the ecu. (the wire was cut)On other wright-ups we are told to connect the orange wire from the KA dash harness to the orange wire on the ecu. We are told this is the igniton signal wire which tells the ecu to run the ignition. Do so leaves the relays with out that signal wire, unles they too are to be spliced into the same wiring.
We are stumped and have rewired it all the different available ways but to no avail. We have not found any odly gorunded or broken wires yet and we have torn apart 80% of the harness. Any help would be greatly appreciated.
