Have a few questions..... i was suprised that the swap was straight forward i thought it would be 1inch longer but its actually allmost the same (length) .. i was told this is from a r33 gt-s and came with axles/bolts everything fits just right except i need to source bushings...
The problem is it didn't have the bushings with it and i'm trying to source them ASAP.... anyone knoe where i could look? i tried the search and spl i think is the only one that came up.. i don't want to use/add washers unless i can't source them.... i swapped the cover and counted the teeth, 48 teeth and has s48:11 stamped on it. could this be 4.11?
any info on where i can get these bushings would help or alternate... thanks
