InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Sat Jun 25, 2005 2:22 pm
um... you removed all the guides? That's not a good idea. You're only supposed to remove the one on top of the upper chain.
Also, you must turn off the car, disconnect the TPS, start it back up, and then set the timing, or else your timing will jump around like a 2 year old on crack.
