I did remove both upper guides(top and side). I assumed that was ok since many otheres had done it. I did not diassemble the cams or idlier. I only took of the valve cover, distribtor and top portion of front cover.
I did everything in this post except, I adjusted the timing wrong
zerothread?id=105618
When I adjusted the timing correctly, It was the same as before I disconnected the TPS.
