nlzmo400r »
https://forums.nicoclub.com/nlzmo400r-u5000.html
Fri Feb 13, 2004 2:06 pm
well guys, im a long time fan and former owner of a 24o, however now i drive an o2 altima. Im looking into getting a 92 24o hatch that is clean as can be, however has some minor mechanical problems. I figured with me being a bit rusty, and you guys still having these cars, you'd be able to help me. The car's valve cover gasket is leaking, however its been leaking for so long that its developed leaks in multiple places and has cause further problems:
1. Valve cover gasket leak2. All belts are swolen from oil and need replacing3. Plugs are clogged from oil and need replacing4. Front crank case is also leaking (no cracks, but leaking?)5. Tie rod bushings have swolen and bursted and need replacing (which is now allowign water into tie rod assembly)6. (not related to leak) but the odometer and speedo are both dead (im assuming new gear in odo. and speed cable?)
Other than these problems the car is immaculate, and i would only be paying 15oo bucks for this car (93k actual miles/1 owner). I brought it to Nissan to have a tech look at it, and between parts and labor, they want 17oo to fix it ALL. I know i could do most of this (if not all) by myself, with an FSM. If anyone here could give me an estimate on how much this would cost, or ANY advice, it would be GREATLY APPRECIATED. thanks in advance guys, sorry for such a long post- Rob
