SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Fri May 06, 2005 12:48 pm
I agree here. If this wire is reletively thick, like coax cable, then the braided wire your seeing should be silver in color and wrapping around a another cable, that will actually contain several more wires. If you only scrapped the outter "braided" wiring, its nothing more than a ground, but if you managed to slice some other wires, and have gotten them to touch that braided wiring, then you could have problems. I doubt this is the case, as you mentioned you are running a "POWER WIRE". Im assuming for an amplifier.
Q45's have an extensive power system that is nearly overloaded. If you are running amplifiers and speakers that require lots of juice and the alternator and battery arent up to the task, these addistions could be causing some electrical issues. What was the power wire addition for, and what problems are you seeing?
Thanks.
