Need help quick!!! '93 J30
ceenotes1
Car: chess, fixing things that dont work
HELP!!!I have a '93 J30 that I just bought about 2 weeks ago from a private owner. Changed all the belts (including timming), oil, filters, plugs immediately. Just pulled up in front of the house after driving in 98 degree NY weather with the AC on for about 2 hours of running around. Now after sitting for about an hour and a half the car wont start at all!! It will turn over for about a second then die out. WHATS WRONG????????
pimpingurz
does it crank? what is it doing and not doing? more info please, im sure someone on here can help.
Q451990
Could be a loose battery cable, bad battery, or starter relay?
Heath
ceenotes1
yes it cranks but it doesnt turn over. battery cable is good and put in different battery with same results. i'm guessing fuel problem or crank position sensor...
