need help putting new fog light bulbs in
NorCal_N/A
Car: 1993 300zx N/A
so i took it all apart and im to this point here.....how to i put the new fog light in, i thought the stock one with the wire would just pop out and then just put the new one. so im stuck.
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
You may have to cut and splice onto the existing wire
NorCal_N/A
Car: 1993 300zx N/A
really? you would think they would make it like the nissan maxima's to where it just simply snaps in. has anybody had to replace a fog light bulb?
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
What you have in your hand in the first pic is the bulb assembly. New bulbs should come with that blue wire:
awesomekasim
Car: 1991 300zx TT 5spd
When i replaced my bulb, i pried off the old bulb connection (the silver clip in your 3rd picture) and clamped on a new female connector to slide the new bulb in. Very simple
NorCal_N/A
Car: 1993 300zx N/A
BigTDogg (MA) wrote:What you have in your hand in the first pic is the bulb assembly. New bulbs should come with that blue wire:
yea the new bulb is connected to that blue wire in the 1st picture. im just confused about how the metal piece at the other end connects with the clear rubber thing thats covered by the black tape.
NorCal_N/A
Car: 1993 300zx N/A
awesomekasim wrote:When i replaced my bulb, i pried off the old bulb connection (the silver clip in your 3rd picture) and clamped on a new female connector to slide the new bulb in. Very simple
ok can you try to explain it a little more please. im not to smart on this electrical stuff. send me a PM or just write on here. Thanks, sorry im like stupid with this stuff lol
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Then splice the two wires together using a butt connector and a crimper. DO NOT wrap the wires around each other and then electrical tape them up. That WILL cause a fire. A good electrical repair kit at Auto Zone is no more than 15 bucks.
awesomekasim
awesomekasim
Ace2cool's method works as well but crimping a female connector on the factory harness will make the bulb easily removable and replaceable
NorCal_N/A
Car: 1993 300zx N/A
awesomekasim wrote:Image
ok thanks guys. i really apprciate it. where could i found some of these female connectors awesomekasim? autopart store? and are they called anything specific? thanks
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
If you use the typical connector available in the local stores, pull the wire all the way through and have enough to loop back a little. Those connectors are not easy to get a good crimp and many times the wire will pull straight out when you try to disconnect. I usually loop a bit of the wire back and solder the connection, then heat shrink tubing over the connection. This way, the crimp is still making good contact and the solder will hold it in place.
awesomekasim
you can get them at any auto parts store.
Agreed with marty1mc. At the very least, i would crimp the connections VERY well and heatshrink it. Heatshrink tubing can also be found at the auto parts store. Crimp the female connector on the main harness and slip the tubing on the wire of the new bulb, connect the bulb to the harness, slip the tubing on, and heat it up with a lighter till it shrinks and seals the connection
NorCal_N/A
Car: 1993 300zx N/A
ok thanks guys i just put them in! i appreciate it!
Ace2cool
awesomekasim wrote:Ace2cool's method works as well but crimping a female connector on the factory harness will make the bulb easily removable and replaceable
Only reason I didn't suggest that was because I saw how little wire is left on the stock housing, and didn't think that it would be a very good idea to cut any more off.
NorCal_N/A wrote:ok thanks guys i just put them in! i appreciate it!
Glad to hear it's sorted out. Have fun with your Z, Lord knows we need foglights in Cali.... :tisk:
