You might want to fully reinstall the lower bolts to remove the pressure off the input shaft if you use this method. Plus your rear main seal will thank you.JeromeS13 wrote:Remove the bolts connecting the transmission to the trans crossmember. Then, simply jack up the rear of the transmission (at the output shaft). That'll give you some extra room between the bell housing and the firewall.
-Jerome
