NEED HELP! Problem with installation FC Comander to S14a!
artjom85
Car: 200SX S14a
Hello.
I have Nissan 200SX S14a, year 1999.
Today I tried to install Apexi FC Comander ( number on the box : 414AN016 ,On the ECU model serial No: PFC SR2016 020-0755 ) and I have the problem with pins.
Like I find in internet I should change some pins (22 to 30; 30 to 40; 40 to 30 ; 31 to 22 , and relocat 106 to 104)
as I found here http://nissansilvia.com.au/forums/index ... pic=206041 . Pin 104 should be empty !
But in my car pin 104 is already has wire.
And I can't find same ECU Harness diagram like in my car.
Her is the link http://media.sxoc.com/contributors/s13f ... uide08.pdf in the bottom you can see S14a ECU Harness.
Somebody can you help me please.
Thanks
leprecaun96
Car: 96 S14 and 97 s14a
Hey if it makes you feel better, and I know it won't I'm having the same issue. mine is a JDM s14a kouki 97.
